Post by ROBBIE » Sat May 13, 2017 7:45 pm
Anton wrote:
zook123 wrote:Jimny Steering Bar?
Yes. Also a "front UJ diff do-burry-whatsit", aka a front prop flange bolt head.
Not sure if I should give it to you or to Darrell. I'll let you guys work it out between ya. ;)
Can see it now, the uj looked one piece, I should have gone to sec savers
Post by Darrell » Sat May 13, 2017 10:35 pm
Anton wrote:
Darrell wrote:I'll just say it's from my GV and hope it's not too easy.
Steering bar drag link...? Not sure if I'm using the correct terminology, but the bar that goes from the drag link to the pitman arm, is that the ball joint bit that drags the drag link bar?
Something tells me it's not. But worth a shot.
Nope..
zook123
Post by zook123 » Sun May 14, 2017 10:06 am
Track rod end?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by Darrell » Sun May 14, 2017 11:26 am
zook123 wrote:Track rod end?
Nope.
Post by Darrell » Sun May 14, 2017 7:18 pm
Just a little bigger..
Untitled hh.png (74.52 KiB) Viewed 21342 times
Post by donkeychomp » Sun May 14, 2017 9:03 pm
Brake line
Jezz
Post by Jezz » Sun May 14, 2017 9:14 pm
Air con or power steering banjo union ?
05 Jimny on 33s
Post by Darrell » Sun May 14, 2017 9:26 pm
Your both on the right track :thumbup:, but not correct.
Post by turbo-tom » Sun May 14, 2017 9:44 pm
Injector leak off bango?
Post by Darrell » Sun May 14, 2017 9:54 pm
turbo-tom wrote:Injector leak off bango?
nope.
