Grand vitara G16b engine ignition timing
cam12
Re: Grand vitara G16b engine ignition timing
Post by cam12 » Sun Jan 29, 2017 5:37 pm
Thanks i will have a good look around
cam12
Post by cam12 » Sun Jan 29, 2017 6:07 pm
thanks
Rhinoman
Post by Rhinoman » Fri Feb 03, 2017 12:49 pm
The monitor coupler should be there but won't have so many wires in it if its an OBD2 vehicle, personally I just use the scan tool to fix the timing. I would have to check the schematic for the GV, some versions of the distributorless G series engines have a resistor to tweak the timing to allow for manufacturing tolerances although they usually have a sticker on the timing cover with the resistor code.
