Looking for G16 convention parts
Hi guys thinking of doing the 1.6 upgrade in my 410 can get the engine easy enough but the G13 box is proving more tricky does anyone have one?
- stevepsj413
Re: Looking for G16 convention parts
Ive got a couple kicking about, came off of breakers that I never drove. Think i even have engine mounts and gearbox mounts cut from a 413 chassis.
Awesome what you wanting for them? And where abouts are you
- stevepsj413
Im in York mate, would want 50 for box and 20 for mounts. Think if your putting the 1.6 into the 1.0l then you mite need some parts from a g13 engine, like the flywheel, engine mounts, and maybe sump and oil pickup pipe depending on what suspension setup your running. Theres a good guide in the how-to guides on here that mite be useful to you.
