Help major steering wobble NEWBIE
Stoney12306
Re: Help major steering wobble NEWBIE
Post by Stoney12306 » Sun Nov 27, 2016 10:46 pm
I've checked everything over the weekend guys and nothing seems to have cured it
How can I measure the angle of the axel what instruments should I use in ready for selling it
Everything I've tried isn't working surely someone's experienced this befor it's so vicious the last test drive it
Nearly had me off the road
Post by ScottieJ » Sun Nov 27, 2016 11:05 pm
If you have an IPhone, go into the compass, swipe across and there's an angle reader, just hold your phone against the diff flange.
You can get angle finder apps for most smart phones.
Stoney12306
Post by Stoney12306 » Tue Nov 29, 2016 7:44 am
Thanks mate will try tonight
Stoney12306
Post by Stoney12306 » Tue Nov 29, 2016 11:22 pm
Exactly 13-14 degrees on the diff and the pinion 14.5 what would be the best to drop it down to 10-11 ?
Post by ScottieJ » Wed Nov 30, 2016 8:48 am
That's enough to put you into + caster figures, that certainly won't be helping with the wobble.
Unfortunately the easiest way is to cut the spring perches off, rotate them and weld them back on with the axle sitting at the correct angle. in the US you can get wedges that go between the perch and spring to adjust the angle but I have never found a UK supplier.
Post by ScottieJ » Thu Dec 01, 2016 1:35 pm
Does this have coil springs as well as leafs on the front?
Stoney12306
Post by Stoney12306 » Thu Dec 01, 2016 8:48 pm
What would you say the correct angle should be ? Yes it has also got springs and shocks
Post by ScottieJ » Thu Dec 01, 2016 10:28 pm
At ride height the pinion flange should sit at 10*
Reason I ask is because I saw this pic and had a feeling it was the same Sj
It looks like the suspension is really stiff and doesn't flex, that can't be good for handling and I would try to soften it up if I were you.
Possibly loose the coils and go back to normal shocks rather than the struts, the back could be softened up as well.
In that situation you should end up cross axled like this.
Looking at the difference in shackle angles on yours in that situation, something is limiting it, either the shocks are too short or the springs are too stiff, maybe even both.
If you can get the suspension set up better it will perform better and be a lot more stable off-road.
Post by turbo-tom » Thu Dec 01, 2016 11:13 pm
Looks like it's for sale now by looks
Post by twiss » Fri Dec 02, 2016 1:20 am
To emphasize, both of these were stock suspension at the time... the white one is a rental! lol
They both flex quite a bit more than that pic
