nightmare heating
Re: nightmare heating
Yea scottie still there havnt a clue what it is though al put some pics on in 10 mins mate thanks
a
- 1.jpg (39.14 KiB) Viewed 7365 times
- IMG_1872 (2).jpg (37.57 KiB) Viewed 7365 times
- IMG_1878 (2).jpg (49 KiB) Viewed 7365 times
- IMG_1881.png (87.15 KiB) Viewed 7365 times
- car 4578.png (92.92 KiB) Viewed 7365 times
right the engine is vitara 1.6 8v spi, the hose with the red ring around I have put side of the intake manifold on the other pic with the red ring around it , the other pipe coming from the thing on the bulk head I left alone it goes into heatermatrix I think , and the pipe next to it I connect that to the smaller pipe coming from next to the bottom rad hose from water rail as in picc , thanks
Does everything look in the right place anyone tell ? Thanks
Yes that looks correct.
Thanks dan
- SlimGrim
- Winching along now
Good luck with getting it running cool
, my temp gauge got very high (like 7mm off of the red zone kinda high) driving back from Buxton but I had been doing 80 for a solid couple of hours haha, should really get a decent rad fan
___________________
What condition is the Radiator in?
When I started getting issues like this it was a. Needed a flush, b. the cap needed replacing and c. there was air in the system!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Just bin over and fitted the new thermostat ran it for 5 mins wif the cap off n topped water up then ran it for bout half a hour with fans on n temp hit 103 n red light came on so turned it off n it was making some loud boiling noises n filled expansion bottle up
Tbh mate the radiator find arnt in the best of condition so gunna put a new rad on as a last resort , then am stuck matbe engine swap lol , thanks
Have you had a pressure test / sniffer test done?
Might be worth looking at that
