I have made a snorkel for my vit (1995 swb) with some 2" flexey tube & two feet of alloy pipe with a K&N air filter on the end sounds great, however I have noticed it seems to louse power? (Missing Hight rev's)
any ideas!!
Vitara help.. Bit of Advice Needed!!!
Re: Vitara help.. Bit of Advice Needed!!!
It sounds as though your snorkel is to restrictive, ie your not getting enough air to your engine. If you dont have enough air you cant burn the fuel efficiently so you wont get your revs up. Try using some 4"piping!
Dan
Dan
- urbanzook
- Winching along now
sounds like the air is restricted
use bigger pipe or remove the filter,
but befor you go mad try removing the snorkel an seeing if it gose back to how it was,
Nice One cheers Chaps.
