Track Rod and TRE part number for Samurai
Post by Jordi » Sun Mar 13, 2016 10:46 pm
Need to fit a TRE sometime soon and ideally want to fit a new rod too but struggling to find the actual rod.
Might brave suzuki but ideally need the part number first.
Cheers (most likely thanks to Darrell)
Re: Track Rod and TRE part number for Samurai
Post by andyrew » Sun Mar 13, 2016 10:48 pm
Fooking expensive i believe.
Twiss may be the guy to speak too.
Post by Jordi » Sun Mar 13, 2016 10:59 pm
Yeah, tried to con Scottie into bringing one back but failed.
Might ask a polish lad i know for a price off his brother who has a Zuk.
Again, part number makes it much easier to explain.
Post by Darrell » Sun Mar 13, 2016 11:46 pm
In the past this was the only site I found selling steering rod and ends.
LHD and RHD , SJ (narrow) Samurai (wide) , so you would need to careful to get the correct part.
http://www.euro4x4parts.com/suzuki_part ... ie_rod_end
Post by Anton » Mon Mar 14, 2016 12:07 am
I think that I might have a few spare track rod ends if you want one, mate. Not sure I can help you with the actual rod though, I have a spare but I have the feeling I'll be needing it - I think I might have bent my current one, and I don't like the idea of trying to straighten it...
Post by Darrell » Mon Mar 14, 2016 12:08 am
I'm not going to risk posting the part numbers as I can't confirm this diagram is SJ or Samurai. As least it will help identify the part names required.
Post by andyrew » Mon Mar 14, 2016 8:58 am
Id have to measure the ones in the barn but
Im sure that 413 and samis are the same its
Just a longer adjuster fitted between the tie rod
And tre. I think.
Post by twiss » Mon Mar 14, 2016 1:10 pm
You want me to just post you one Jordi? I think they are €55 for both samurai rods (45 i think for narrow track) including the TRE
Not sure on postage but I'm willing to bet its a lot cheaper than buying the bars in the UK.
Tbh I could get my parts guy to send it to you in the UK as he uses DHL a lot
