ah but have you lowered them? if you have 2" lift springs you will need to lower the bumpstops on the front, i used sone 2" box section for this. then on the back axle because the bumpstops are on the sxle i bolted some 2" box section onto the points on the chassis that the bumpstops would usually hit. I will take some pics and show you what i mean.urbanzook wrote:ow them bits yer there there no worrys
stiff springs
Re: stiff springs
- urbanzook
- Winching along now
Re: stiff springs
no there not extended.
hu ill see wot you have dun an make my mined up.
