but on sod all, two things really that should have done before hand, but didn't.
Fails =i had been trying to sort it but ran out of time then was out all night on call and my dad took it for the mot, and didn't have chance to put it right.
i had left it one castle nut loose trying to find the hole for a split pin, and forgot to fit the rest of the split pins, oops
head lights, i knew about
there wasn't much meat left on one of the u bolts, i knew about
Advisory =
the steering bar -if i had painted it he said he wouldn't have noticed, but i forgot and he did, so he asked to have the welds turned down , and he will check i have when i take it back.
split pins - i forgot
so today, I've been sorting it out,
u bolts replaced - job done
head lights being done when i take it back - job done
found out why i couldn't fit the split pin, found a snapped one in the hole, so left that with my dad today
so all I've got left to do is paint the steering bar my dad had sorted out on the weekend for me, as i was working. And put the steering back together
woohoo will be able to finish it in the morning and book it back in.
:double thumbs:
oh tester said its running a bit lean, he recons quarter of a turn should do it, so shall do that
