front brake upgrade.
- robbie1985
the front calipers are in a bad way and i was thinking of doing a refurb on them. I've been reading up on a possible upgrade to LWB front discs and caliper to go with my rear disc conversion. from what i have read its a simple case of just swapping them over or do i need to swap over the hub carrier to? seem a little bit to simple to work!
Re: front brake upgrade.
Just the rotors/discs and the calipers. Bolt on, bleed brakes, laughing.
