Stats696
Post
by Stats696 » Wed Aug 04, 2010 10:50 pm
My diff has gone on my sammy, can I swap it for a Santana diff or are they different ratios?
Henry
- Suzuki Guru
Post
by Henry » Wed Aug 04, 2010 10:55 pm
Aslong as its the sammy and not the 413 then you will be alright
Stats696
Post
by Stats696 » Wed Aug 04, 2010 11:10 pm
Yea it's a sammy, in previous posts I didn't realise there was a difference between the two!!! Newbie error!! So the sammy and Santana run the same ratio diffs? Are they pretty much the same anus then? I'm thinking of buying a santana as a donor.
Henry
- Suzuki Guru
Post
by Henry » Thu Aug 05, 2010 10:05 am
Yes they run the same ratios.
I would begin to tell you what the differences are... but suzuki changed their mind about everything so often... its pointless!
