A strengthened steering bar?
Because boy have i made a mess of mine today! If i carnt find a uprated one, i will straighten it out in the press and tack some angle iron along it!
Is anyone running?
Re: Is anyone running?
hi henry,
bent mine a few times, thought about beefing it up a bit but just worried where the force will go when i hit something.
would rather straighten bar out than have to replace broken bits.
cheers kev.
cheers kev.
Soon sorted it this afternoon...
As you can see it was a bit bent....
Soon straightened it though after wedging it in with some blocks!
Then can you guess what this used to be
cut a section out and welded it along the steering bar for that added bit of strength
Also managed to bent the rear bumper back into shape with reverse and a tree!
