Offset wheels
- donkeychomp
Re: Offset wheels
Why junk the spacers for offset rims? Chances are they won't be 100% true and you'll have wobbly wheels like the junk I got from Ray. Can you not just get fatter rims? Or stick with what you have...
Re: Offset wheels
I don't want cut and shut ideally, a few companies I've seen do offset wheels brand new...didn't know if I was missing any other brands that do a similar thing.
I'd been wanting some new wheels for a while, so I thought why not go offset
1987 - Suzuki sj410q
31" Maxxis MT764 Bighorns
Winch & winch bumper
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
http://www.youtube.com/user/Matt270498
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
Re: Offset wheels
I would rather run offset wheels over spacers any day.
Remember you can buy them mass produced and not all offset wheels are built by an idiot
Tbh if your Sj isn't lifted that much I wouldn't worry about having too much offset, just enough for the thres to clear the springs at full lock is perfect.
Re: Offset wheels
You've always got the option to fit Samurai axles with vitara R&P's. Your 410 will have the same spring spacing and axle width I had, I made new spring seats and put Sammy axles on my 413 for the same reason. Moving the pivot point outwards means the front wheels turn in a more "natural" arc, and don't rub as much.
I'm not sure it's an option that's going to suit you really, especially knowing that you want to keep your 410 relatively standard, but I thought I'd mention it in case (long shot) it suited your needs better.
Re: Offset wheels
2003 GV1600 sport
1995 Vitara SWB
1995 Vitara SWB
Re: Offset wheels
They're the ones i have my eyes on
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
Re: Offset wheels
Will they fit. Com
Is a good site for working out offsets
And tyre changes.
Offset rims over spacers for me. But that's
Because I love a bit of dish
And tyre changes.
Re: Offset wheels
Pretty sure stock wheels have 0 offset so a -30 wheel should be the same as running 30mm spacers on stock wheels, plus they're 1.5" wider than stock wheels so the outer rim would be an extra .75" further out.
- donkeychomp
Re: Offset wheels
I smeared it on my face for the photo at the 2013 meet after dropping Scottie's shackle pin in 3 feet of sloppy goop, diving in after it and coming up empty but muddy.
Was a good day!
Was a good day!
