Ginger_boy
Post
by Ginger_boy » Fri May 21, 2010 8:03 pm
I want to rebuild my spare tbox as the one that is on the truck is getting quite loud, the radio is now being turned up more and more.
Has anyone got any idea where i can get the nessasary seals bearings/gaskets from as a kit. Or is it a case of strippping the box and replacing all thats knackered from suzuki or where possible a bearing/seal stockists
- The Boss
Post
by ScottieJ » Mon May 24, 2010 11:21 am
sorry about the delay, not been online all weekend
transfer box rebuild parts list....
Gasket part numbers –
(Bought from main dealer)
Main Case - U29525A80050
x1
Front Case – U29535_80050
x1
Seal Part number/sizes –
38x50x8_TC R23 NBR
x1 (simplybearings.com)
OS38x60x08
x2 (bearingboys.com)
Bearing sizes –
6306 NR circlip grooved
x1
63-22X_NSL
x1
62-28 2RS
x3
bearings sizes recognised by all bearing supliers.
Ginger_boy
Post
by Ginger_boy » Fri May 28, 2010 3:53 pm
cheers for that
Contacted a bearing supplier yesturday made me laugh a little as he miss quoted the 62 28 and the 63 22 bearings and quoted me in excess of £700 for the lot. He was a bit miffed when he requoted with the proper bearings for them to come out at £40
- The Boss
Post
by ScottieJ » Fri May 28, 2010 5:08 pm
No Worries matey
Could you post up how much all the bearings and seals comes to after you have bought them all as I just offered to help Ferris rebuild an old 410 tbox I have and it would be good to know what sort of price he is looking at for the rebuild.
Scott
d86
Post
by d86 » Sun Jun 13, 2010 6:06 pm
i allways use bearing king in sheffield.
on a side note.
king pin bearings x 4 £18
rear axel seals £2 each.
found them cheaper than simply bearing who i used to use.
just google them
go for the cheapest postage they are here next day..
tony
- The Boss
Post
by ScottieJ » Mon Jun 14, 2010 9:26 am
awesome, cheers tony, I'm just rebuilding some sammy axles for my sj so that should save me a few pennies!
