have I bought the correct brake cylinders
keyring
Post by keyring » Thu Mar 26, 2015 11:37 pm
Hey guys, I have an early sj410, and obviously is the same set up as stated in the pinned thread
Originally I had only looked at the left side, I gave the parts store my reg and when the parts store asked if my cylinders had bleed nipples, I said yeah
However, I've noticed now that only the one side has the bleed nipple, so does this mean I've ordered the wrong ones, or do the bleed nipples have the same thread as the brake pipe fittings and its just a case of removing a bleep nipple and putting the brake pipe in?
Re: have I bought the correct brake cylinders
Post by Darrell » Thu Mar 26, 2015 11:44 pm
Unfortunately if yours is as the above diagram you will need the correct pipe in / pipe out cylinder.
replacing the bleed nipple for a pipe won't work.
Post by Darrell » Thu Mar 26, 2015 11:54 pm
Just nabbed this from Brakesinternational
Didn't know there so many different ones :S
screenshot-nimbusscreencaptureff-at-everhelper-dot-me 2015-03-26 23-50-13.jpeg
screenshot-nimbusscreencaptureff-at-everhelper-dot-me 2015-03-26 23-50-13.jpeg (443.75 KiB) Viewed 9162 times
keyring
Post by keyring » Fri Mar 27, 2015 12:03 am
Absolute legend!! Cheers mate, means I can hopefully try get the ones I actually need sourced tomorrow and get an exchange on what I have
Cheers dude :D
keyring
Post by keyring » Fri Mar 27, 2015 12:05 am
Looking at that image, its the top two I need, although if anyone knows different, please correct me
My sj is a B reg, so I dunno if that makes it mk1 even though I'm sure its a 84/85
Boyes
Post by Boyes » Fri Mar 27, 2015 12:58 pm
Do you have the original cylinders? Would be worth measuring the distance between the cylinder.
keyring
Post by keyring » Fri Mar 27, 2015 4:38 pm
I haven't yet took the old ones off, but new cylinders should be delivered next week for the top two on that list
Post by Darrell » Fri Mar 27, 2015 6:45 pm
The top two show they are for the early model with drums up front as well.
keyring
Post by keyring » Fri Mar 27, 2015 8:53 pm
You're joking? Haha
So I've ordered the wrong ones? :(
