Potential charging issue
Ladaman
Post by Ladaman » Sun Feb 01, 2015 11:21 pm
When out and about today, the volt meter I have fitted was showing all sorts of readings. Anywhere from around 13.5V right down to about 11.3V
The voltage would tend to drop if I turned the heater fan speed up, and go up if I turned it off.
As regulators seem to be "set", does it just sound like the alternator needs a strip and good clean?
Also, I have a pair of LED spotlamps, and I thought the idea was to allow loads of light for very little power. I think they are 20W each. Well when I turn those on, it can knock the volt meter reading right down to the low 10V area, knocking about 2V from the electrical system. :S
Ideas?
Re: Potential charging issue
Post by ScottieJ » Sun Feb 01, 2015 11:49 pm
Could be the regulator breaking down, stuck brushes or even just a dodgy wire/connection.
Give it a good strip and a clean.
Post by Anton » Mon Feb 02, 2015 1:44 pm
I kinda wonder how many SJ's do this without us realising - anyone think this might be normal SJ behaviour? I kinda want a voltmeter now for mine...
I'm very curious!
Rhinoman
Post by Rhinoman » Mon Feb 02, 2015 10:12 pm
Where is the voltmeter wired to?
Ladaman
Post by Ladaman » Mon Feb 02, 2015 10:48 pm
Good question.
I can't actually remember, but I think it might be the supply to the cigarette lighter socket.
Does it matter?
Where should it be to?
Rhinoman
Post by Rhinoman » Tue Feb 03, 2015 9:39 am
It may make a difference, the cigarette lighter outlet comes through a fuse, I would want to verify the readings with a voltmeter connected directly across the battery. Is this an automotive voltmeter or just a cheap panel meter? automotive meters are usually quite heavily damped so you don't see transients.
