Main beam light stays on all the time
dazerede
Post by dazerede » Fri Jan 30, 2015 6:33 pm
Noticed a problem with my lights the other day I took my dash out ages ago and had a tidy up with the wires and that and ever since I done that the main beam light stays on :/ if found the wire and put a switch on it but when the switch is on and I put the main beam leaver on and the blue light goes brighter on the dash :/
Anyone help also the interior light doesn't work no more :( also noticed three is only 1 wire going to the fuse from the main beam wire
4” calmini lift kit :)
Online
d_r_1989
Re: Main beam light stays on all the time
Post by d_r_1989 » Fri Jan 30, 2015 6:51 pm
Is the horn fuse blown? Mine brought main beam light on all the time. It only has one wire but the other side has a brass connector to the fuse next to it :thumbup:
dazerede
Post by dazerede » Fri Jan 30, 2015 10:03 pm
I've changed the fuse and ye the horn doesn't work either :(
Where does the brass connector go mate
Online
d_r_1989
Post by d_r_1989 » Fri Jan 30, 2015 10:18 pm
The wire goes in one side of fuse and the other side is a bit of brass that joins to the fuse next to it, you can see it on the back of the fuse box.
dazerede
Post by dazerede » Sat Jan 31, 2015 8:23 pm
We'll I looked earlier and all I can see is a wire going in the fuse box and nothing coming out of it :/
Will look better Tmoz as doing both front wheel bearings
dazerede
Post by dazerede » Mon Feb 02, 2015 7:23 pm
Online
d_r_1989
Post by d_r_1989 » Mon Feb 02, 2015 9:45 pm
Are you sure the fuse isn't blown and is getting contact on both sides?
