vitara transfer box
vitara transfer box
hi
can anyone tell me,is there gear mod you can do to a standard vitara transfer box that lowers the gearing down for purely off road use, i have seen a second transfer box mounted directing onto the output of the standard transfer box giving lower gearing and creating a"rock lobster" box
thanks
phil
thanks
phil
- Ladaman
- Suzuki Guru
Re: vitara transfer box
I'm not sure about different gears for a Vitara, but my mate fitted an SJ transfer box to the back of the Vitara one.
There is some info on it here.
http://forum.suzukiclubuk.co.uk/vi ... =22&t=8881
It is very low ratio now. I know because I've followed him, and I can't go SO slow.
hi
i have seen these pictures your mate has done a real good job here looks the real biz
regards
phil
regards
phil
You can get low ratio gears for the Vit tcase, on the Vit box only low range is changed.
hi
thanks for that, do you now how i could obtain a set?
phil
phil
I don't know who would sell them in the UK, maybe Rob Storr. The big US vendors all sell them, Calmini, Trail Tough, LROR. You need to search for Suzuki Sidekick or Geo Tracker which is what the Vitara was called over there.
hi
perfect much appreciated
thanks
phil
thanks
phil
- donkeychomp
hi
thanks very much for your help and everyone else who has taken the time to respond,all very much appreciated
phil
phil
