Sj410 compression test results
Rhinoman
Re: Sj410 compression test results
Post by Rhinoman » Tue Dec 30, 2014 1:37 pm
Give it a good clean and then check it again, its probably just dirty.
courior
Post by courior » Tue Dec 30, 2014 3:03 pm
a very small air leak blowing "up" into it is ok.. new ones have that. Did u have a lot of oil/gunk in the connecting pipework?
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Sj410red
Post by Sj410red » Wed Dec 31, 2014 5:21 pm
No, the pipes seem very clean, there was a split in one near where it goes on PCV so I trimmed it off and refitted it, would the split cause any problems?
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
courior
Post by courior » Wed Dec 31, 2014 6:02 pm
Split wouldn't cause oil consumption. Did u try blocking it off for a week or so?
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Sj410red
Post by Sj410red » Wed Dec 31, 2014 8:15 pm
No not as yet, that will be my next job now you've answered my question about pcv, I guess I can just find a bolt to go in pipe off of valve pipe to block it, and use a j clamp to secure it and same for other end?
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
courior
Post by courior » Wed Dec 31, 2014 9:18 pm
Yeah or get an extra bit of pipe and a bolt in each ending if u get my drift :)
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Sj410red
Post by Sj410red » Thu Jan 01, 2015 2:33 pm
Ok thanks, will give it a go for a few days
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
courior
Post by courior » Sat Jan 24, 2015 7:26 pm
Dont know how well u got on... but mine started making smoke again a few days after i replaced the pcv so wasnt that (even tho it was shot)... was for sure the valve stem seals... So i took a chance and put some "Silverhook Stop Leak" into the oil. Its not an oil thickner but a rubber seal treatment.. after about 200 miles of having this in the motor i get absolutley no smoke on startup and she is running sewing machine smooth now! I think it had this stuff in it and when i changed the oil i removed the treatment and hence it leaked again... So now every oil change ill throw a bottle of this in (only a few quid) so well worth it... saved pulling the head and disturbing all the head gasket etc...
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by ScottieJ » Sat Jan 24, 2015 11:14 pm
Personally I'm not a fan of those types of additives, I would rather just do the valve stem oil seals, better to fix the issue than hide it in my opinion.
courior
Post by courior » Sun Jan 25, 2015 6:40 pm
yeah i know... im thinking not to bother with it again and next oil change ill get the head stripped and cleaned. im on the lookout for a 1.6 to wack in tho. :)
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
