Powertrax Lock Right done WRONG
tomread47
Re: Powertrax Lock Right done WRONG
Post by tomread47 » Fri Jun 13, 2014 10:10 am
i removed the 2 thrust washers behind the 2 gears
it has abit off play but most clunking noises have gone
Rhinoman
Post by Rhinoman » Fri Jun 13, 2014 11:18 am
Thrust washers are usually there to prevent wear when rotating parts are against non-rotating parts, are you sure that removing them is a good idea? maybe thinner washers would be better.
Ladaman
Post by Ladaman » Fri Jun 13, 2014 5:26 pm
Mmmmm, not sure that's a good idea.
I'm sure it was the surface of the diff carrier, the cast parts, that the thrust washer runs on that I machined 0.25mm off.
I did consider thinning the thrust washer down by this amount, but it would be a pig of a job being so thin in the first place.
Post by mike harris » Sat Jun 14, 2014 10:19 am
STOP !!!
Don't use that car until you put them trust washers back in !!!!
There very important !!
Machine the diff or sit and emery down the trust washers.
Mike
Post by ScottieJ » Mon Jun 16, 2014 10:32 am
You should be able to get thinner thrust washers rather than machining the diff.
tomread47
Post by tomread47 » Mon Jun 16, 2014 2:14 pm
i took both the thrust washers out behind the 2 remaining small gears
Post by mike harris » Tue Jun 17, 2014 6:59 pm
Yeh machine the diff, that's what my pro diff builder did with mine
d_r_1989
Post by d_r_1989 » Wed Dec 31, 2014 3:05 pm
Sorry for bringing back this thread, ive just got a lockright and concerned about having to machine the diff. Is this always or dependant on wear etc?
Ladaman
Post by Ladaman » Wed Dec 31, 2014 4:17 pm
It should be just down to Suzuki and Lockright tolerances. You don't really want to be putting worn parts back into the diff.
I can help if you are concerned as I'm not far away, and mine works a treat now after the mods.
mike harris wrote:Yeh machine the diff, that's what my pro diff builder did with mine
I must be a pro too. ;)
d_r_1989
Post by d_r_1989 » Wed Dec 31, 2014 4:28 pm
That's great thanks! I'm planning on pulling my diff this weekend all being well. So I'll see how I get on.
I was told by a very knowledgable friend of mine that a lot of people run with no washers on the side gears with no problems so getting abit uncertain with a reliable installation.
