ScottieJ wrote:By me being an idiot doing it on my phone and typing something wrong
Glad I'm not the only one who does stuff like that!
ScottieJ wrote:Also do you have any idea if the weight for that bmw derv is just the basic engine, I.e. Built block and head with no ancillaries? the weight might add up once everything is bolted to it, a G16 in the same state is 60kg
No idea, although I'd love to get confirmation from somewhere. BMW do put tech info in some of their brochures (which is where the 1:0.66 top gear figures came from) but I do not know for sure if it's 117kg. That info might be made up on the spot, or it might actually be lighter! It's a 4 pot all ally engine, related to their 4 pot ally petrol.
I think even if it's 150kg, it'll be fine in a Dutton. They often get cast iron V6's in them, which have to weigh well past that (the Essex is supposedly between 172kg and 195kg, cologne around 172).
I might try to get confirmation on engine weight, as 136hp and 204ft-lb is crazy, and I've just looked on autotrader and seen whole cars going for £chips - a crash damaged one might go for a song if you search hard enough.
But going beyond the weight of the thing, I'd be worried about all that torque munching the t-case, props, diffs, halfshafts. Even the leaf springs probably wouldn't survive that for very long if you had a lead foot.
It's a seriously overpowered engine for an SJ. Although you have to admit, it sounds like it'd be a lot of fun! It takes the 1490kg 3 series to 60 in 9.9, I suspect a 930kg SJ is going to be somewhat livelier...
And it's 60mpg in a heavy car. Assuming that the Jimny doing 15% less mpg than the Ignis with the same engine is correct, that means the SJ could, in theory, manage up to 51mpg with this engine.
Although low to mid 40's is probably more realistic, but that's still freakin' awesome for an SJ!
The gearbox is actually what really interests me. I suspect that the BMW engine is more than an SJ can cope with (it's a nice dream, but I don't know about the realities) but the gearbox?
Mated to a more sensible diesel engine (toyota all alloy 99kg diesel maybe?), it could make sense. Maybe. If the 1:0.66 thing is true.
The other thing I thought about was a Range Rover classic overdrive, but that's a lot of work, there are no parts out there, and I'm not sure how far off topic I've gone...
waynesworld wrote:Its as i guessed then, the ldv gearing, its all i could of thought it was, just wanted to make sure before i decide on which engine to look at going with.
open to anything really, we will see, thanks guys for the info
For something bigger than an SJ, I would seriously consider the beemer engine. I think it could make sense. It's got to be as easy to source now as the XUD9TE engine, probably as reliable if not more so (especially if you remove the swirl flaps, the little screw in them can come loose and get sucked through the engine and make mincemeat of the turbo - later engines have a redesigned plastic one).
Other engines I've considered swapping into an SJ:
- VW CFWA 1.2 TDI. 3cylinder all ally, 75kg all up inc turbo etc. 75hp/120lb-ft. Rare though (too new, released in 2009).
- Toyota 1ND-TV 1.4 TDI. 4 cylinder all ally. 99kg all up inc turbo etc. 75hp/120lb-ft (99-05) 90hp/140lb-ft (05-08) 99hp/150ft-lb (09-current). 1999-2002 Yaris D-4D's come up for £peanuts now and then too.
- BMW M37 1.5 TDI. 3 cylinder all ally. ?kg. Different power outputs up to nearly the same power output as the 2.0 mentioned above, but it's not even in cars yet, so £££££. I'll probably revist this idea 10 years from now. Will be in the 1 series, 2 series, maybe 3 series (seriously!) and the Mini Cooper D. Should be very lightweight and powerful. Has 6 speed rwd transmission already mated up and suited to the engine (except mini version).
- Audi 1.5 TDI - supposedly a 3cylinder all ally TDI, but very little info about it out there. I should imagine it's very similar to the VW 1.2 TDI if not almost identical. Not officially even announced. Again, 10 years from now maybe...
- Zuk M15a ignis engine. 4 cylinder all ally petrol. You probably don't need to hear about that though as you're looking at dervs!
