kibris
Post
by kibris » Tue Dec 09, 2014 9:14 am
Hi, the track rod end on the drivers side is fubar - no problem I have one to fit - but what happens with the passenger side? looks like its not replaceable? what happens when that goes?
Sorry just realised its in the wrong section please move
Post
by twiss » Tue Dec 09, 2014 10:45 am
You can't replace that end, usually have to get a new track rod :(
There was somewhere online in the UK that you could buy them from... think they were £80-100
Post
by Anton » Tue Dec 09, 2014 4:43 pm
To say you *can't* replace it is going a bit far - if you know what you're doing you probably can, but I'm not sure of the legalities of messing with steering components like that. Bolt on is fine, but (at least in the UK) if you cut off a rod end and weld a new one on, you might be looking at an MOT fail if they realise.
Having said that, if you drilled it, tapped in a thread and wound in a new rod end? Can't be any different to the other end, surely?
Post
by ROBBIE » Tue Dec 09, 2014 6:38 pm
Weld on will fail, your not allowed to apply heat to steering components, Ive got a bar in the shed with a welded on track end
Post
by donkeychomp » Tue Dec 09, 2014 10:05 pm
No heat to steering components?
- WP_20141208_012.jpg (259.49 KiB) Viewed 8018 times
Post
by ROBBIE » Wed Dec 10, 2014 8:49 am
As long as your not man isn't on here I think you'll be ok
- The Boss
Post
by ScottieJ » Wed Dec 10, 2014 9:27 am
The actual MOT guidelines state 'excessive heat' I think. question is how exactly are they going to tell if it's been freshly painted?
Post
by Anton » Wed Dec 10, 2014 3:23 pm
ScottieJ wrote:The actual MOT guidelines state 'excessive heat' I think. question is how exactly are they going to tell if it's been freshly painted?
The less I say about my drag link, the less you lot can let slip under interrogation, all I'm saying is that I know it's safe.
