Starting problems ????
lukey4x4
Post by lukey4x4 » Sun Dec 07, 2014 4:15 pm
Hi all need a bit of help , we stuck here , so finally gettin round to wiring the sj up today n hit a problem i have the vitara loom all sorted and wired up , but i didnt have the egnition barrel n that just the black cap that u turn wif a screwdriver lol , so i can turn the engine over but got to keep screwdriver turned when i let go just goes off , anyideas people ?
Ig barrel
Ig barrel
Rhinoman
Re: Starting problems ????
Post by Rhinoman » Sun Dec 07, 2014 5:10 pm
That thing in your hand is the antenna for immobiliser, where is the key?
lukey4x4
Post by lukey4x4 » Sun Dec 07, 2014 5:19 pm
I bought a immo and a key off a guy on here who programmed them to my ecu , av tried putting key through that ring but does the same ,
Rhinoman
Post by Rhinoman » Sun Dec 07, 2014 5:23 pm
Have you wired up the Check Engine Light? it was probably me that supplied the immo but I don't remember which ECU you have what is the part number?
lukey4x4
Post by lukey4x4 » Sun Dec 07, 2014 5:31 pm
Yea mate it was you didnt realise there , i have no clocks in mate not sure about engine check light what is it
Rhinoman
Post by Rhinoman » Sun Dec 07, 2014 5:38 pm
That's a 4u2 ECU.
The Check Engine Light lets you pull fault codes, you can wire up a temporary one with a small bulb or LED (with resistor). On the Vit there was a six-way connector under the bonnet near the driver's side headlight, you need to place a jumper in that to get the CEL to flash the fault codes. You'll have to crank for at least 15secs to check for a cam sensor failure.
http://www.rhinopower.org/diag/cel.html
lukey4x4
Post by lukey4x4 » Sun Dec 07, 2014 5:52 pm
Am not to gud wif wiring lyk but a friend is so o is getting the clocks a permeant fix ? , sorry for all questions mate am not sure on this so will show to a fried so is that to get fault codes up or will it start it after 15 secs thanks
lukey4x4
Post by lukey4x4 » Sun Dec 07, 2014 7:37 pm
So its not the egnition barrel thing mate its sumit to do with the wiring or immo ?
lukey4x4
Post by lukey4x4 » Tue Dec 09, 2014 7:22 pm
Av just notice that mine doesnt have these wires could this be my problem anyone no
Rhinoman
Post by Rhinoman » Tue Dec 09, 2014 7:25 pm
Yes there should be at least one wire there, from the distributor to the bulkhead.
