new to wiring/ colours? new side indicators
AshR1
Post by AshR1 » Sat Dec 06, 2014 9:52 am
Hi, just looking to crimp on some new indicators, original ones have green and black wires on, the new ones i have got have black and yellow wires, i have never done any wiring before but reading a colour chart the green wire and yellow wire arent the same? this mean i cant attach my new indicators? or black to black green to yellow or something else?
thanks
Ash
A Newbie with a 1988 Samurai Hard-Top
AshR1
Re: new to wiring/ colours? new side indicators
Post by AshR1 » Sat Dec 06, 2014 9:56 am
Post by Darrell » Sat Dec 06, 2014 11:20 am
black to black
yellow to green
Should be fine..
Post by Tramp » Sat Dec 06, 2014 12:01 pm
Darrell wrote:black to black
yellow to green
Should be fine..
Unless they are LED (as they are polarity sensitive). If they don't work black to black, green to yellow try swapping the wires - green to black, black to yellow. Then you should be ok.
Fwb2700
Post by Fwb2700 » Sat Dec 06, 2014 7:44 pm
Most be vechles I have done wiring on lately the factory green is ground. And on the new indicator black is ground. But that's only required if your using LEDs if it's standard incandescent bulbs either way will work
Post by Anton » Mon Dec 08, 2014 10:12 am
I have a few different LEDS (most of which were crap and I didn't use) and some of them are bidirectional and some aren't.
The ones I have in my side indicators (the ones usually on the wing) are bidirectional - if I turn them around in the socket, they still work.
