Vitara engine in Sj410
Posted: Sun Feb 09, 2014 9:25 am
by ben_moto501
I'm thinking of fitting a Vitara engine in my project 410. To make sure I get a good running engine I think buying a whole Vitara is the best idea!
My question is, as I also need a gearbox, do I buy a 413 gearbox and conversion plate or just use the Vitara gearbox that will come with the vehicle?
I can see the bigger clutch being an advantage.
Can I do this? Does it affect gearing? What modification is required to get it in there?
Thanks guys!
Re: Vitara engine in Sj410
Posted: Sun Feb 09, 2014 9:28 am
You can use the vit gearbox like scottie has but you will need to adjust the gearbox crossmember to suit, and scottie also had to chop a fair bit out of his transmission tunnel, but that may have been just to get it up as high as possible...
check out his build thread here:
http://forum.suzukiclubuk.co.uk/vi ... ?f=22&t=12
