what happened here?
Posted: Thu Feb 06, 2014 6:37 am
by kiwizook
I sprayed the inside of my bonnet with 1k primer, and this happened in just one spot. anyone know what caused it? almost looks like it didn't stick on properly
Re: what happened here?
Posted: Thu Feb 06, 2014 6:52 am
by dan_2k_uk
Guess there might have been some sort of oil/fluid there that its reacted with or just sat on top of.
Posted: Thu Feb 06, 2014 6:53 am
by ROBBIE
looks like could have been damp or dirty
Posted: Thu Feb 06, 2014 11:05 am
Either damp or oil on the panel.
You can get special solvent panel prep cleaner. Probably find the whole thing needs flatting off and priming again
Posted: Thu Feb 06, 2014 6:31 pm
by kiwizook
I was thinking of just sanding back the affected areas, and then repaint those area's. funny thing is I wiped it down with thinners, so wouldn't expect anything like this
Posted: Thu Feb 06, 2014 6:34 pm
by timwilks13
Dude when i painted my windscreen, someone had previously painted the windscreen in a different colour. I sanded the old paint to rough it up, and cleaned it with white spirit, yet my paint reacted with the old paint and turned out just like yours has. Must have been an oil based paint or something not removed by thinners. I would sand/grind right back to metal and prime first then paint.
Posted: Thu Feb 06, 2014 10:04 pm
by donkeychomp
Orange peel like that can happen for all the above reasons. It can also happen if you lay the paint on too thickly or if it's cold and damp.
Posted: Thu Feb 06, 2014 10:16 pm
donkeychomp wrote:Orange peel like that can happen for all the above reasons. It can also happen if you lay the paint on too thickly or if it's cold and damp.
Also happens if your cak handed with a spray gun.
Posted: Thu Feb 06, 2014 11:33 pm
by donkeychomp
...that too. :hahaha:
Posted: Fri Feb 07, 2014 4:26 am
by kiwizook
Jordi wrote:Also happens if your cak handed with a spray gun.
:oops: :oops:
I'll sand it back, and try again. I don't think it reacted with the paint, as the layer underneath it is the original factory paint, and this was the only spot it did this
