Hi,
I'm assuming the oil pressure warning light should come on with the ignition, then go out when the engine starts.
I can't get it to light up at all, starting to think bulb, ?
Any ideas
Dash Oil pressure warning light.
- ianedwards
- SCUK Addict
Ian.
Ian.
Re: Dash Oil pressure warning light.
Check the bulb
- timwilks13
- SCUK Website Padawan
With the ignition on test between the oil pressure tab and a ground with a multimeter perhaps? That will confirm the oil pressure switch is ok?
