Twiss' supercharger+EFI
Posted: Fri Dec 06, 2013 1:43 pm
Right, I've been talking about doing this for ages.
I thought I would post it all for feedback and to get it straight in my head!
Supercharger
I've been looking at supercharging my suzuki with a blow through set up for a while now, since I saw gonzalo bravo's supercharged zook and now know it definitely can be done.
here is a link to gonzalo's build if you want to take a look, it's some top notch stuff!
http://twistedandes.com/foro/showthread ... 72&page=43
I am looking at using a supercharger from a mercedes, as they are quite easy to get hold of and come in a variety of forms... Ive settled for a supercharger from a W203 as they are quite cheap and available with inlet and output on the same side
This should make it easier to make a manifold for it...
I intend to make a 1 piece manifold that bolts straight onto that surface, but the direction of the pipework will be decided by whatever vitara intake system I end up with
With a standard pulley on them, the supercharger generates about 5.5 psi of boost.
Where mounting to the car is concerned, I am going to try to make a large pivoting bracket, pivoting from the bottom of the engine so the supercharger's weight can keep the belt tight...
I'm going to make it adjustable in a similar fashion to the alternator.
I may have to give up on that idea at a later date, and install a tensioner instead... but I will cross that bridge when I get there!!
What I don't want to have to do:
Ive found a good website about blow through superchargers and SU carbs, which doesn't sound that difficult, but if I'm going to be getting a supercharger I will need EFI to get the most out of it I think.
http://www.mgexp.com/article/how-to-blo ... an-su.html
EFI
So for that I will be going for a megasquirt 2 controller, as I can make most of it myself! Looking at the calculations I think I can put one together for under £200
Engine Components
I will be using a 16v vit inlet manifold (which should be on my engine in the first place), with high impedance injectors, as it makes things work a bit easier with the ECU!
Some Injectors and the injector rail missing from the manifold above:
Im also going to need a high pressure fuel pump to deliver 40-50 psi (maybe more!)
and a fuel pressure regulator (vacuum adjustable so it will supply more fuel under boost)
PCBs and Components
I have all the circuit diagrams for the megasquirt 2.2 board
The reasonably long list of materials is here...
http://www.megamanual.com/v22manual/mass.htm
and the only parts I need to buy already made up are the Megasquirt 2 CPU and a case
I've costed all the individual components for the board at about £80... but that will leave me with lots of extra components remaining due to minimum order quantities!
I already have a distributor with most of the gubbins removed by tim pink, so it just sends a trigger signal. I am going to probably use a ford coil pack (due to price and availability) and modify the megasquirt to run the ignition timing using this guide. I will be using a 4 cylinder wasted spark setup.
http://www.msextra.com/doc/general/sparkout-v22.html
it all will be wired up like this, except using an additional connector to signal the coil pack:
Another mod I will probably do it relocating the MAP sensor. As the standard board has the sensor in the ECU box, I will be relocating it via the DB-37 connector so it is part of the relay box in the engine bay. This will save on running a vacuum hose into the glovebox to the ECU!
Then it will just be the matter of programming it and getting it running!!!
Coil on Plug conversion
Scottie mentioned doing away with the distributor completely (yes please!) and its definitely possible! As the ECU can control all of the advance there's not much point in using it except for sensing when to spark!
I would like to use something like this, as its quite a tidy looking option where I wouldn't have to blank off the dizzy hole, but I doubt they make them to fit zooks!
but I will probably end up with a toothed cam wheel and a hall sensor...
Something like this:
I will have to slightly rewire the ECU internals, but then will end up with 4 logic signals (low voltage, 1 for each plug) coming out of the additional 15 pin connector along with the coil pack connections. These will then connect into an ignition driver, which will actually power the coils
The two methods share one pin which is the ground return, so it will be able to work in this way
That provides connectors for each coil... which are wired up as follows
(actually thats for a wasted spark setup, i would do individual firing as in the diagram above)
If anyone has any comments or anything please go ahead as I'd like to do this one properly
Supercharger
EFI
Engine Components
PCBs and Components
