Super413
Post
by Super413 » Sat Jul 04, 2009 2:56 pm
Morning folks,
I would like to fit a bonnet vent to my 85' JX, this would not just be for show, and is to aid my weber.
Ive never done this before so any ideas on type, or actual instruction would be welcomed.
thanks
Tim
bourneyo
- The Boss
Post
by bourneyo » Sun Jul 05, 2009 12:21 am
see if you can get a vitara 4U2 bonnet scoop cut a hole in your bonnet seal it down paint to match. or you can get a chavvy one from a motor factors or make your own from chicken wire and paper mashe, just make sure you seal it properly!
Dan
Super413
Post
by Super413 » Sun Jul 05, 2009 5:11 pm
would you recommend industrial silicone for the sealing? Im checking out ebay for a vitara scoop!
tim
deathbus
Post
by deathbus » Sun Jul 05, 2009 6:43 pm
silicone retards paint, i wouldnt use it.
sika-flex is good. or any other rubberised seam sealer.
about £4 for a tube, and youl need a mastic gun to apply.
bourneyo
- The Boss
Post
by bourneyo » Sun Jul 05, 2009 11:48 pm
It doesnt need to be watertight. even if you did go through the effort of sealing it there is a wooping great hole on the front!
Dan
Super413
Post
by Super413 » Mon Jul 06, 2009 1:29 am
I had a scout around on the net for the 4u2 bonnet vent but cant see any around, has anyone used anything generic that is similar and looks proffessional on an SJ???
Henry
- Suzuki Guru
Post
by Henry » Mon Jul 06, 2009 8:45 am
Post
by dan_2k_uk » Thu Jul 09, 2009 12:09 am
could just work out where you need the extra space and hit it with a big hammer!!
