Weird noise on start up
ferris
Post by ferris » Fri Oct 04, 2013 6:36 pm
My SJ's been making this weird noise every time i start it up. Its been doing it for quite a while now, so probably time i got it sorted. Any ideas??
Click Here for Youtube Video
http://www.youtube.com/watch?v=GkcjqyLHEos
Re: Weird noise on start up
Post by andyrew » Fri Oct 04, 2013 6:43 pm
Sounds like the starter solenoid is lazy And sstaying engaged
Used to get it on my old skoda.
Christoff
Post by Christoff » Fri Oct 04, 2013 6:47 pm
Yeah that's the starter. Try bump starting it see if it goes away.
Post by Edweird » Fri Oct 04, 2013 7:10 pm
Yeah, as above. Your starter is not disengaging properly after the engine starts.
ferris
Post by ferris » Fri Oct 04, 2013 7:10 pm
Cheers guys. Do you recon its fixable if i strip it down and grease it up?
Post by Edweird » Fri Oct 04, 2013 7:21 pm
ferris wrote:Cheers guys. Do you recon its fixable if i strip it down and grease it up?
Probably. It could be the return spring if it's got one.
Post by Jordi » Fri Oct 04, 2013 7:24 pm
Try a strip an clean. May just be full of crud.
Failing that i've found a few of my local independant auto electrics places to be very reasonable on pice for repair / refurb of parts.
May be worth a look
Post by turbo-tom » Fri Oct 04, 2013 7:49 pm
Deffo starter motor. Strip it down and rebuild. The brushes are really fiddly I found rebuild the bushes around a bit of pipe and slide them down back in otherwise you will be there for ages!!
Post by twiss » Mon Oct 07, 2013 8:26 am
I think that is probably the drive gear spinning on the starter shaft...
the drive gear I believe is only supposed to spin around one way (so it can free wheel while disengaging, once the engine is started)
I would take the starter motor off and see if you can push the gear round both ways by hand/finger.
Otherwise I would have a spare starter ready in case! Mine was making that noise, and now it's dead!
ferris
Post by ferris » Mon Oct 07, 2013 5:34 pm
All sorted now. Stripped it down greased every thing up and the noise has gone 8-) . Cheers guys.
