Page 1 of 3
virtual lift help :)
Posted: Sat Sep 21, 2013 8:54 pm
by hamer
hi guys all going good with the vl
i didnt make new inner arches due to the cage flush against the door screw bolts so i modified the existing inner wing by slicing each corner and bended it up to meet the new 5"sheet i bent to create mud flaps
its worked out pretty good :)
i cut loads out of the bulk head to follow the top lip so naw im confuse how the throttle peddle would go back?
the rear i welded up complete new arches all went good looks proper job :)
might raise the rear flloor and to lift the tank a few inches but what do i do with the filler neck as the chassie would be in the way?i like the tank underneath dont like the idea of being upside down with petrol tipping over me lol
so two things i need some advise with guys...throttle and tank :)
Re: virtual lift help :)
Posted: Sat Sep 21, 2013 9:27 pm
by turbo-tom
internal tanks i fine if there built to a good leak free standard. mine is custom made and inclosed behind me and feels fine. but i guess its personal choice really.
Posted: Sat Sep 21, 2013 9:38 pm
by dazerede
Ye I was thinking of getting a costom fuel tank for mine and wack it in the back as my fuel tank is a bit rusty plus I already patched it up once lol
Posted: Sat Sep 21, 2013 10:01 pm
by hamer
my bro rolled his the other day and i had my finger ramed in the tank breather pipe stoping it all leaking all into his anus so keeping it away tucked underneath lol
Posted: Sat Sep 21, 2013 10:03 pm
by turbo-tom
ahh but like mine ive got a one way valve in the breather pipe going onto a mini k and n filter so the petrol can breath etc then if i was to roll over it shuts down.. you can get them on ebay
Posted: Sat Sep 21, 2013 10:12 pm
by hamer
turbo-tom wrote:ahh but like mine ive got a one way valve in the breather pipe going onto a mini k and n filter so the petrol can breath etc then if i was to roll over it shuts down.. you can get them on ebay
sounds good mate :) il have a look
Posted: Sat Sep 21, 2013 10:21 pm
by turbo-tom
there a pretty good bit of kit there not expensive either. just remember to put it in the right way around compare to what i did i found out the hard way! :lol:
Posted: Sun Sep 22, 2013 6:20 pm
by ferris
How much did you cut out? I think i went as close as i could to the throttle pedal without cutting the fixings off. Still had to do a bit of messing around to get it back on.
Posted: Sun Sep 22, 2013 6:36 pm
by dan_2k_uk
I did similar to Ferris and left the little bit with the throttle pedal on intact and cut a few little triangle bits to male Tue new plate step out to it.
If you have already removed it I guess you could fit the pedal assembly back on at an angle and bend the arm to suit.
Posted: Sun Sep 22, 2013 7:10 pm
I only had to remove the pedal stop, it now just hits the floor.
I didn't cut out the captive nuts to mount the pedal or have to modify the pedal.
Can you post a pic?
