alternator repair, need new reg for sj410 alt..
Posted: Thu Sep 05, 2013 6:59 pm
by Jay18
my sj is charging at 15v so i ned a new regulator for it, does anyone know where i can get one?
i found this one but not sure if the 413 and 410 use the same alt..
http://www.ebay.co.uk/itm/Alternator-Vo ... 4169932adc
the alternator on my SJ is a mitsubishi 12v40A alternator..
it has on it:
400 - 80010
the label is faded so its hard to tell what it says but in big letters it says A1T33771
if anyone can help me find a regulator then that would be great thanks, need to sort it asap before i fry my electrics lol...
Re: alternator repair, need new reg for sj410 alt..
Posted: Thu Sep 05, 2013 9:41 pm
by Darrell
Well that fleabay jobbie looks like a pressure switch :S :er:
Posted: Thu Sep 05, 2013 9:42 pm
by Darrell
Found this though
Posted: Thu Sep 05, 2013 9:49 pm
by Darrell
just had a look in the workshop manual and it says you have to unsolder things to get that alternator apart :thumbdown:
Above also says the max level is 14.6volts so your not much above.
Posted: Thu Sep 05, 2013 11:05 pm
by Tramp
It may depend on your multimeter, I have one that only shows full volts..... 14.6v will round up to 15,
Posted: Thu Sep 05, 2013 11:57 pm
by Edweird
I've got two. One is pretty good, the other....It'll tell you if there is a voltage, but I don't trust it to tell me accurately.
Posted: Fri Sep 06, 2013 5:24 am
by Jay18
I've used two different multimeters and they say between 15.4 and 15.6v so it definitely needs to be sorted, thanks for that darrel, will get one of them regulators ordered soon..
Posted: Fri Sep 06, 2013 8:56 am
by suzukisteve
found some part numbers if you wanted a new unit.
remy number dra3217
universal number una662
torquex number txa1282
sovereign number sa769
:thumbup:
