Page 1 of 3
Rear brake problems. SORTED!!!!!
Posted: Tue Aug 27, 2013 11:55 pm
by andyrew
Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
Swapped hoses over tried old rubber hose too
Swapped calipers over both okay
Bled with calipers up top
Fitted another master and servo ( cheers jordi)
Clamped off rear feed flexi hose from wing to chassis front brakes working fine good solid pedal
Blanked off one side of axle t piece . Drivers rear good solid pedal
Blank other side of t piece and Try with Rear passenger and it just lets pedal to the floor
So im left with the t peice or copper pipe being at fault which makes no sense.
will try again tomorrow. Im heading home
Re: Ahhhhhhhhhhhhh!!!!!!!!
Posted: Wed Aug 28, 2013 12:21 am
by Ladaman
Sounds like a long frustrating day.
Good idea to go home. Hopefully you will see the obvious mistake straight away next time you look at it, and think what a ****.
Good luck.
Posted: Wed Aug 28, 2013 12:39 am
by Edweird
You sure the servo is working? Duff connection, vacuum leak or something? Sounds like a dead servo to me at least.
Re: Rear brake problems. Loosing the will
Posted: Wed Aug 28, 2013 8:03 am
by suzukisteve
as ladaman said andy, some times you jus gotta walk away and come back to it later to be able to see the problem. hope you get it sorted bud
Posted: Wed Aug 28, 2013 9:01 am
Discs or drums on the rear?
Posted: Wed Aug 28, 2013 11:33 am
by andyrew
Converted to discs.
Should have kept the flipping drums
Posted: Wed Aug 28, 2013 9:30 pm
by Rhinoman
andyrew wrote:Converted to discs.
My rear disc conversion went in the skip and I went back to drums.
Posted: Fri Aug 30, 2013 8:02 am
by suzukisteve
how are you getting on with this andy? managed to sort it ok?
Posted: Fri Aug 30, 2013 12:19 pm
by 4x4rick
andyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
Andy... I have braided hoses across the rear axle a good t/pipe
will bring along with me also got the servo if u fancy swapping stuff around to eliminate the one fitted
Posted: Fri Aug 30, 2013 4:18 pm
4x4rick wrote:andyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
He's on the second servo and master cylinder now.
