are the 410 and 413 alternator the same?
Posted: Wed Aug 21, 2013 6:36 am
by Jay18
I know the standard 410 alts are 40 amp and the 413 55 amp, but I want to know if a 413 alt will bolt straight in place of a 410 alt as mine is knackered and isn't charging anymore and i have a 80 amp hour battery that i need to be able to charge, so I have to keep jumping my zuk using a caravan battery I have in the boot..
Re: are the 410 and 413 alternator the same?
Posted: Wed Aug 21, 2013 10:47 am
by timwilks13
i know that i was unable to fit my 410 alternator on a 413 block as the mounts are closer together on the 410 alternator. Also the wiring is slightly different on the 413 alternator than the 410.
Posted: Wed Aug 21, 2013 11:01 am
by suzukisteve
I remember seeing someone on here adapt a transit alternator. However I cant remember who or what engine
Posted: Wed Aug 21, 2013 11:22 am
it was a transit alternator with a vacuum pump on the back of it... the pump ended up getting removed though
Posted: Wed Aug 21, 2013 11:45 am
by suzukisteve
whey! that was it! lol
Posted: Wed Aug 21, 2013 3:28 pm
by Jay18
think I need to find out what alternator is on mine then cause its a Mitsubishi alt 55 amp.. I thought it might be a 413 alt cause they are 55 amp
Posted: Wed Aug 21, 2013 3:46 pm
by suzukisteve
what year is yours as ill look it up while im here at work
Posted: Wed Aug 21, 2013 4:51 pm
by andyrew
find a local auto electricians
My local motor factors wanted £190 for an alt
electricans fixed it for £28
Posted: Thu Aug 22, 2013 4:25 am
by Jay18
1987
