1.6 mpfi conversion, what is needed?
Posted: Thu Aug 08, 2013 10:24 pm
by Jay18
other than the bits needed to do a normal 8v conversion like a 413 box, flywheel, starter etc..
what else is needed?
I know I would need a sammy fuel tank with fuel pump built in..
Re: 1.6 mpfi conversion, what is needed?
Posted: Thu Aug 08, 2013 11:05 pm
by dan_2k_uk
Loom and ecu.
Posted: Thu Aug 08, 2013 11:07 pm
by turbo-tom
engine mounts.
Posted: Thu Aug 08, 2013 11:57 pm
by Jay18
I know about the engine mounts, have to move them when ya do a 1.6 8v conversion aswel, so it's just electrics then?
the block the same as a 8v?
Posted: Fri Aug 09, 2013 1:13 am
by gp7186
Yeah as already been said loom and ecu to start. If you get a vitara fuel tank there is a tapped ring which the fuel pump mounts this can be swapped over to the sj tank you will see there is a pressing on the sj tank just drill a 70mm ish hole in the centre of it and weld down the ring and your sorted. Fuel lines will need to be replaced I re worked the donor vitara lines to fit my sj. Its much easier to get a donor vehicle then you can swap everything over and then sell the rest of the parts not needed. Some people fit the vss from the vitara clocks but I aint and it runs well. Heres a pic of mine when I just fitted it
Posted: Fri Aug 09, 2013 1:22 am
by Jay18
thanks mate, what rad have you got in yours? and how have you fitted it?
Posted: Fri Aug 09, 2013 2:44 pm
by gp7186
The rad is a 42mm 2 core alloy 'racing' one from a honda civic they are very small and fit nicely with a few simple brackets and it only cost £70 new from ebay but you can get standard civis rads for half that new and they are designed to cool a 1800 vtec . I also used a cooling fan from an escort rs turbo as again they are very compact but powerful and very easy to mount heres some pics
Posted: Fri Aug 09, 2013 2:56 pm
by Edweird
Blue wires and hoses. It's a well known fact of science that those make a car go faster. As does red paint and flames.
Posted: Fri Aug 09, 2013 4:43 pm
by gp7186
Edweird wrote:Blue wires and hoses. It's a well known fact of science that those make a car go faster. As does red paint and flames.
Il have u know those blue rad hoses gave an extra 10bhp alone
Posted: Fri Aug 09, 2013 9:05 pm
by windsor
You for got wonky raceing stripes make your car quiker two
