Page 1 of 2
help on a sj 410 engine conversion
Posted: Wed Jul 10, 2013 7:47 pm
by lukey4x4
doing a engine conversion to my sj410 belived to be a c reg , am going to pick a vitara 1.6 8v engine that comes with everything up at the weekend am just after sum advise on what I need to do or replace etc
gearbox
engine mounts
wiring
exhausts
or does anyone have any step by step guides thanks ...
Re: help on a sj 410 engine conversion
Posted: Wed Jul 10, 2013 7:52 pm
by dazerede
You will need a 1.3 Suzuki sj gear box
maby a 1.6 exhaust
Umm
A welder and a grinder to move the engine mounts a bit
Posted: Wed Jul 10, 2013 7:58 pm
by dazerede
Posted: Wed Jul 10, 2013 8:14 pm
by lukey4x4
thanks very much mate will have a read through that the engine am getting comes with the manifold do u think I will need vit full exhaust system thanks...
Posted: Wed Jul 10, 2013 8:17 pm
You can use the standard exhaust it will bolt straight on
saves you making an exhaust up when you do the job
Sj exhaust my restrict it a bit but not too much
Posted: Wed Jul 10, 2013 8:40 pm
by lukey4x4
thanks for the info mate will do that see how it runs
Posted: Wed Jul 10, 2013 8:43 pm
You may also want to look into fitting a 1.3 radiator as well, that will cool a 1.6 but not sure a 1.0 rad will
Posted: Wed Jul 10, 2013 9:00 pm
The 410 exhaust will not bolt straight on, even if it did it would be far too small for a 1.6. easiest thing to Sonia get a complete 413 exhaust but if it was me I would use the 1.6 manifold and downpipe and then make the rest of the exhaust from scratch.
You need to make sure you get the complete ignition system and coil with the 1.6
I know a lot of people say its fine with a 1.3 rad but from my experience of everyone running the 1.3 rad they are the ones who usually end up getting hot while Offroading compared to those of us with the 1.6 rad.
You will need to make new engine mounts, that write up is for a 413/samurai 410 engine mounts are different.
413 gearbox is needed
84 is a bit of a changeover year as well so you might even need to modify the gearbox mount on the chassis, take a photo of it and ill be able to tell you if you will or not.
Posted: Wed Jul 10, 2013 9:28 pm
by lukey4x4
thanks for the info mate something to think about with the exhausts, the engine comes with the wiring harness not sure about coil, will I need to change complete wiring harness ? , sound like a big job with engine mounts and gearbox mounts is it a thing local garages could do.. thanks I will try and take a pic tomorrow and put it straight on thanks
Posted: Wed Jul 10, 2013 9:33 pm
Is it a carb engine or single point injection?
