Page 1 of 2
there is no spark on my 410
Posted: Thu Jun 13, 2013 9:52 pm
by dazerede
Today and yesterday I had trouble with my carb I tried starting my sj the startor motor was spinning and engaging and there is fuel going to the carb and it fired up after 2-3 mins of turning the key and it fired up choke was out purhapse my carb needs cleaning it started alright in the morning drove it to college at 9.00 and then I started it at dinner time at 1.00 drove it 3 miles to the postoffice to get a pastie and then tried starting it but it wouldn't I tried pumping the accelerator and I didn't help and after a couple of attempts it started.
Also I was going offroad and the sj stalled as I was in 2nd gear and it wouldn't start then so I got out and.gave it a.push jumped in and it.only just starter
It starts allright when.cold but if its a bit warm it won't start
I have.heard the a rover metro Su carb will fit straight on a 410 manafold just got to dril a hole out abit
If anybody has a su carb for a 410 that they will be willing to sell I'm willing to buy it
Re: problem with 410 carb
Posted: Thu Jun 13, 2013 10:00 pm
First step give it a strip down and clean. 410 carbs are awesome little carbs, no need to upgrade in my opinion.
However I don't think it's your carb if it doesn't do it when cold.
Did you put new points and a condenser on it during the rebuild? If not do that and make sure the gap on the points is correctly set. It's only £10-15 for them both.
Posted: Thu Jun 13, 2013 10:06 pm
by dazerede
Points and condensor I'm only 18 Scottie what are they
I didn't rebuild the engine I bought a better one of a mate which he had just removed from a working 410 and I just wacked it in my sj
I might have a better look Saturday afternoon give the carb a clean and go from there
Chears Scottie
Posted: Thu Jun 13, 2013 10:08 pm
by turbo-tom
Posted: Thu Jun 13, 2013 10:21 pm
Sorry they are both components in the dizzy, you'll need a set of feeler gauges to set the points up ;) maybe try the ones in your old dizzy if you still have it?
Posted: Thu Jun 13, 2013 10:26 pm
by dazerede
Chears for the advice
Going to clean the carb on Saturday check the dizzy might see how much new leads are and new dizzy are also might give it a set of new plugs all at the same time
Posted: Thu Jun 13, 2013 10:36 pm
You don't need a new dizzy, just points and a condenser ;) they are the only parts of your dizzy that will ever really need replacing. I used to carry a set of feeler gauges at all times just in case the points gap needed adjusting :lol: it was rare but always the first thing I would check if it started running badly.
did you keep your old engine?
Posted: Thu Jun 13, 2013 10:46 pm
by dazerede
I have a spare engine but it.doesn't have a carb or dizzy
Ok I will check the dizzy first
Posted: Thu Jun 13, 2013 10:49 pm
Unless darrell beats me to it ill take some pics of the service manual pages about replacing and setting the points for you tomorrow :thumbup: only takes 5mins to do it.
Posted: Thu Jun 13, 2013 10:51 pm
by dazerede
Ideal Chears dude I don't have a feeler gauge but i might leave 10 mins earlier for work to see if my boss has one if soo I will adjust it there and then if not I will borrow the.feller gauge
