what do you lot think
Posted: Tue Jun 11, 2013 7:29 am
by windsor
I cant deside weather it would be worth me going for a add a leaf system or saveing and buying new springs what do u rhiink
Re: what do you lot think
Posted: Tue Jun 11, 2013 7:57 am
by turbo-tom
Add a leaf are okay but its cheaper in thelong run to get new springs.
Posted: Tue Jun 11, 2013 9:57 am
by ROBBIE
Get new springs. Addaleaf are ok but I they arnt the best of rides and will kill the top spring. Also they are a very hard ride
Posted: Tue Jun 11, 2013 11:43 am
Add-a-leafs suck
Can't see anything wrong with those springs in the picture.
Posted: Tue Jun 11, 2013 12:52 pm
Looks ok. AAL isn't something i'd recommend.
If you want lift go for Llama springs, YJs or RUF and rascal rears.
Posted: Tue Jun 11, 2013 7:42 pm
by windsor
Allread got ruf and rascle but my front left has droped about 10mm i noticed today
Posted: Tue Jun 11, 2013 8:21 pm
by turbo-tom
Its gansta lean mate they all do it!
Posted: Tue Jun 11, 2013 10:06 pm
windsor wrote:Allread got ruf and rascle but my front left has droped about 10mm i noticed today
Just swap them from side to side if one is lower
Posted: Tue Jun 11, 2013 10:15 pm
by windsor
Lotta effort to leval them out tho init it will be fine am shure lok
Posted: Thu Jun 13, 2013 3:11 pm
Ahhhh everyone knocks add a leaf but it kept my knackered springs working for 4 years or so!
I would only recommend using add a leaves if your springs are knackered anyway, but they again its a fine line of how knackered they can be!
If they are really bad, the springs can end up bending around the ends of the add a leaf.
Mine obviously weren't so bad as they were in there for years, and in the end it was the add a leaf that snapped, not the regular springs!
I only put the add a leaves in cos they were a free way of fitting my bargain tyres on... if you can afford it, get proper lift springs! Can't recommend Llama 4x4 springs enough, mine are really comfy compared to standard springs! Although, I have heard that their heavy duty springs are way too rigid... I went for standard thickness leaves
