Extended Bump Stops For SPOA
Famerbennie
Post by Famerbennie » Mon Jun 03, 2013 10:42 pm
Can Anyone Help With The Above (Pics, Ideas)
Re: Extended Bump Stops For SPOA
Post by Jordi » Mon Jun 03, 2013 10:44 pm
I just removed my front stops, welded in some 50mm box and refitted the stop to the box sections.
On the rear i just welded in some 50mm box to the plate where the stop hits.
I'm not SPOA just lift springs.
Post by Jordi » Mon Jun 03, 2013 10:48 pm
Post by ScottieJ » Mon Jun 03, 2013 10:57 pm
You want to set the bumpstops to a point where they stop the spring as it goes flat under compression, over flexing leaf springs shortens their life.
