kill switch
- suzukisteve
- Suzuki Guru
kill switch
with car thefts on the rise and my suzuki being a soft top ive been thinking about security.
has anyone ever fitter a switch to isolate the battery from the ignition? was thinking of using one of those battery isolator switches that you see used with winches.
has anyone used em or had any experience with em?
pickle power!
Re: kill switch
Seen a few in back of gloveboxes etc.
Not the most secure but might do something to stop em.
No different to a hidden switch for the coil or similar.
- Ladaman
- Suzuki Guru
Re: kill switch
I've got a kill switch, and they are good for that, not high security though.
For security I agree with Dan and go for a switch on the coil circuit. It doesn't even need to be hidden, as it could be "disguised" as a fan, spot lights or other obvious switch only you know what it really does.
Or even take the steering wheel off!!
- suzukisteve
- Suzuki Guru
Re: kill switch
yeah good idea as it goes. just cant bear the thought of some fucker stealing her
pickle power!
- dazerede
Re: kill switch
I have a isolator switch in mine but ain't telling u where
4” calmini lift kit
4” calmini lift kit
Re: kill switch
I don't have an isolator switch, however you won't be starting mine in any hurry
Re: kill switch
i had a cut switch in my old 410 coz it was a raggy. if your your good at wiring and relays n stuff you could do something cleaver, i drove an old car once where you had to flash the main beam twice to turn the immobilizer off! very cool B)
- justaddmud
- Can I have a tow
Re: kill switch
those red key kill switches are a good safety measure, however not the last work in anti theft as the keys are generic.
when i got my SJ there was a slim rocker switch inside the glovebox that cut the coil, i didn't know about it till one day when it just would not start, chased it back to the switch that i had hit throwing my wallet in.
Re: kill switch
taking the wheel off worked for Mr Bean!
Re: kill switch
Sounds secrative of has it just got important parts missing right now?ScottieJ wrote:I don't have an isolator switch, however you won't be starting mine in any hurry
