Moving Axle Forward - info please?
Cyprus Geoff
Post by Cyprus Geoff » Fri May 10, 2013 4:10 am
I often read of people moving the front axle forward an inch when doing a change of springs? Some kits (TT for example) have spring plates with holes pre drilled for moving the axle.
Does this not affect the steering in some way or other? Do you have to re-mount the steering box or similar? Just what is involved?
Thanks,
Geoff
kibris
Re: Moving Axle Forward - info please?
Post by kibris » Fri May 10, 2013 7:29 am
Cyprus Geoff wrote:I often read of people moving the front axle forward an inch when doing a change of springs? Some kits (TT for example) have spring plates with holes pre drilled for moving the axle.
Thanks,
Geoff
Hi Geoff, if you want to move the axle forward, you dont have to redrill - its only necessary if you dont want the axle to move- ie on the back as it fouls the petrol tank - the steering is not affected by moving an inch or so forward.
OllieSJ
Post by OllieSJ » Fri May 10, 2013 9:54 am
seems a pritty coll thing to do, if u decide to do it would enjoy the build thread
