Page 1 of 2
Sj413 carb
Posted: Sun Apr 14, 2013 8:59 pm
by Crisdolf
I believe it's auto choke,vehicle runs fine but you have to pump throttle when u start it cold and keep rev up till warm,when I was doing the filters other day and a general clean up I took top cover off carb and notice a cable holding flap shut ? Any ideas ?
Re: Sj413 carb
Posted: Sun Apr 14, 2013 10:29 pm
by penpontgreenwoodwork
mine had the same start up symptoms. I noticed the little pipe from below the green plastic valve on the off side of the carb had perished. Changed it, starts fine.
Re: Sj413 carb
Posted: Sun Apr 14, 2013 11:20 pm
by Crisdolf
Yes ,sorry first message should read cable tie in top hold flap shut ,there's wires to carb so I take it auto choke is electronic ?
Re: Sj413 carb
Posted: Sun Apr 14, 2013 11:28 pm
by Edweird
I thought the autochoke used some kind of thermal wax or something
Re: Sj413 carb
Posted: Mon Apr 15, 2013 8:06 am
by ROBBIE
Yep thats what i thought ed
Re: Sj413 carb
Posted: Mon Apr 15, 2013 11:02 am
by Crisdolf
I'm not sure either will take some pics and put on
Re: Sj413 carb
Posted: Mon Apr 15, 2013 6:49 pm
The standard carb auto choke is wax, it's on the left as you look over the driver side wing. Darrell posted all the carb diagrams up on the "standard 413 carb service" thread, shows everything. the cable tie is a mystery, I take it it's on the port nearest the engine?
Re: Sj413 carb
Posted: Mon Apr 15, 2013 9:27 pm
by Crisdolf
Yes it is
Re: Sj413 carb
Posted: Tue Apr 16, 2013 11:30 am
by Crisdolf
This is it pics taken from drivers side wing
Re: Sj413 carb
Posted: Tue Apr 16, 2013 11:32 am
by Crisdolf
penpontgreenwoodwork wrote:mine had the same start up symptoms. I noticed the little pipe from below the green plastic valve on the off side of the carb had perished. Changed it, starts fine.
Yeah pipes a bit perished too,where can I get some ?
