M series engine thread (for Cyprus Geoff)
Posted: Mon Mar 11, 2013 4:26 pm
1.3 M13a 1328cc DOHC 16v MPFI (Swift)
Bore x Stroke 78mm x 69.5mm
Compression Ratio 9.5:1
91.2 hp @ 5800rpm, 86 lb/ft @ 4200rpm
1.3 M13aa 1328cc DOHC 16v MPFI VVT (Jimny)
83.8 hp @ 6000rpm, 81 lb/ft @ 4100rpm
1.5 M15a 1490cc DOHC 16v MPFI VVT (Swift/SX4)
Bore x Stroke 78mm x 78mm
99.9 hp @ 5900rpm, 98 lb/ft @ 4100rpm
1.5 M15a 1490cc DOHC 16v MPFI VVT (Ignis)
Compression Ratio 11:1
111 hp @ 6400rpm, 105 lb/ft @ 4100rpm
1.6 M16a 1586cc DOHC 16v MPFI VVT (SX4 2wd)
Bore x Stroke 78mm x 83mm
102-107.4 hp @ 5600rpm, 121.7-129 lb/ft
1.6 M16a 1586cc DOHC 16v MPFI VVT (SX4 4wd)
102-107.4 hp @ 5600rpm, 140 lb/ft
1.6 M16a 1490cc DOHC 16v MPFI VVT (Swift Sport)
Compression Ratio 11:1???
125 hp @ 6800rpm, 109 lb/ft @ 4800rpm
1.6 M16a 1586cc DOHC 16v MPFI VVT (Swift Sport 2012)
136 hp @ 6900rpm, 118 lb/ft @ 4400rpm
1.8 M18a 1796cc DOHC 16v MPFI VVT (Aerio - Australian Liana)
Bore x Stroke 83mm x 83mm
Compression Ratio 9.6:1
123 hp @ 5500rpm, 130 lb/ft @ 4200rpm
All info gleaned from Wiki, so it's probably wrong.
If anyone has any tech specs they know are wrong, or anything I should add to this (deck heights, valve clearances, gasket specs - anything - let me know and I'll edit the post).
