free wheeling hubs info
Posted: Mon Mar 04, 2013 4:19 pm
by dazerede
One of my freewheeling hubs is hard to turn going from free to lock
I heard its just strip them down and clean them
Is there a guide thing that I can use as I would proberly do it wrong
Re: free wheeling hubs info
Posted: Sun Mar 10, 2013 10:14 pm
by penpontgreenwoodwork
Hi All
One of the free wheeling hubs on my recently aquired 413 doesn't seem to want to be free. It turns to the free position easy enough but it won't spin and is still turning the prop. Any thoughts?
Posted: Sun Mar 10, 2013 10:31 pm
Yes the section that slides in and out has probably become dissconected from the outer section, remove the 6 small 10mm bolts and remove it, re-assemble and refit, it's held on with a spring that sits in a groove in the splines.
http://forum.ih8mud.com/79-95-toyota-tr ... build.html
Posted: Sun Mar 10, 2013 10:55 pm
Thanks for that. Can this be done without removing the hub from the vehicle?
Posted: Sun Mar 10, 2013 11:20 pm
If what I think has happened you'll just need to remove the front section to fix it. Just the 6 10mm bolts.
Then just start at this point in the write up i linked.
- image.jpg (56.79 KiB) Viewed 4766 times
- image.jpg (74.71 KiB) Viewed 4763 times
- image.jpg (83.02 KiB) Viewed 4763 times
Posted: Mon Mar 11, 2013 10:23 am
Done it! Thank you so much, invaluable knowledge.
Posted: Mon Mar 11, 2013 10:56 am
by dazerede
might try this at the weekend
as it is very hard to turn
