87 Santana SJ410 New cam needed!
Posted: Mon Feb 25, 2013 12:07 pm
Well after buying my anus and removing the rocker box cover I was horrified on the state of the rockers and valve springs
I don't think the car had ever had an Oil change! Yet when I drove it home there did not seem to be any smoking issues?
You could not see the bloody springs and the whole rocker assembly was jet black. I set to work using Jizer, white spirit, Brake cleaner and anything else I could get my hands on to try and remove the crud! Ive used flat headed screwdrivers to loosen the crud, wire brushes and it is beginning to look a bit better.
I had not planed to do major engine work so this has been a setback. Having cleaned much of the crap off (with the head still bolted on) I can now see the cam. It looks like the last lobe of the cam is badly worn (near the back of the engine) so I need to find a replacement cam
Can anyone recommend a place to pick up one at a reasonable cost?
Have to say the costings on this thing now are beginning to spiral, not what I planed at all :(
