vitara 8v head on sammy?
Posted: Fri Jan 18, 2013 9:23 pm
by colinl
Hi All i have recently destroyed my 8v vitara engine and decided to strip it for parts.Anyway the question is would the cylinder head and Nikki twin choke fit on my 1.3 engine and would there be any difference in performance?
thanks
Re: vitara 8v head on sammy?
Posted: Fri Jan 18, 2013 9:35 pm
Slightly bigger ports and valves and a cam that is designed more for torque as far as I'm aware.
Should give a small performance boost and it bolts right up
Posted: Fri Jan 18, 2013 10:20 pm
by colinl
Cheers thats all i needed to know so after my next pay and play i think im on a head change!
Posted: Fri Jan 18, 2013 10:30 pm
Just make sure that the cam pulley has the same style teeth as the crank pulley, there's two types available flat and round teeth.
change the cam pulley to match whatever's on the crank if it is different.
Posted: Sat Jan 19, 2013 4:02 pm
by colinl
ScottieJ wrote:Just make sure that the cam pulley has the same style teeth as the crank pulley, there's two types available flat and round teeth.
found this out the hard way when i fitted the 1.3 back in and all the pullies and the alternator were different!
