Page 1 of 2
Garage flooded!!!
Posted: Thu Jan 03, 2013 9:11 pm
by 12callum
With all the rain we've had at least the beast got to see some of it, even if it was just sat in the garage!!!
- image.jpg (862.52 KiB) Viewed 5552 times
Also a pick to confirm that I have put it on the wrong way!!!! Silly me
- image.jpg (754.1 KiB) Viewed 5552 times
Also anyone know what these are and if I need them with the webber carb?
Or can anyone see anything I've done wrong as hopefully tomorrow she will be finished off and hopefully started for the first time in over a year!
Re: Garage flooded!!!
Posted: Thu Jan 03, 2013 9:20 pm
by dazerede
same about the flood as my garage roof leaks a bit as it is made of felt and doesnt last long but soon it will all go and there shall be a double garage
im a 410 man really so i cant help u on ur 413
Posted: Thu Jan 03, 2013 11:21 pm
by donkeychomp
Hard to tell what that is...might be the oil pressure switch?
Alex
Posted: Thu Jan 03, 2013 11:32 pm
by dan_2k_uk
Dont know what they are exactly but some kind of vaccum for the old carb.
Anyway I know you need to blank them. Just put the hoses onto each other or put a screw down the hose.
As long as nothing can get in or out it will be fine.
Posted: Thu Jan 03, 2013 11:51 pm
by 12callum
I have been searching the web for the webber carb info, it seems as though the one that most of you have posted about, is different to mine! I'm going to see if I can change it over tomorrow, will I still be able to use the gaskets or will I have to get some new ones? If not does any one have an SU carb with adaptor that I can buy or maybe swap either way?
Posted: Fri Jan 04, 2013 12:01 am
by dan_2k_uk
gaskets will be alright if they've only been fitted for a bit and engine not used in anger. Just remove it carefully.
Would just stick with what you have now as its going to be your quickest easiest route to getting it running.
Dan
Posted: Fri Jan 04, 2013 12:07 am
Im an SU convert. I know those pipes are vac advance and mine are just blocked off. I know when i converted my SJ carb to a daishitsu carb it didnt have enough pipes so the SJ vac advnces got blocked off too. That still runs fine.
Sorry about the garage. Never makes life easier when stuff like that happens.
Posted: Fri Jan 04, 2013 12:11 am
by 12callum
I think you might be right dan, the sooner I get it running the sooner I can move on to the seats then get it taxed and tested! Are you over this way any time soon?
John
Posted: Fri Jan 04, 2013 12:23 am
by Darrell
You don't need either of those valves with a weber. One was part of the auto-choke and the other part of the idle-up system.
Posted: Fri Jan 04, 2013 12:24 am
by dan_2k_uk
I might be out and about tomorrow afternoon as it happens. Depends whether a delivery I'm waoting in for comes early or not.
If I am out and about I will chuck you a PM over
