Page 1 of 2
disc rear axle
Posted: Tue Oct 02, 2012 9:30 pm
by Jay30685
Right guys, I'm doing leaf over spring so I'm going to have my axles off, I've got a spare pair of axles that I can do the work on to make it a straight swap.
I'm wanting to weld the rear diff up and build the axle to have rear disc.
Can anybody tell me what I need? I've got a spare pair of axles so have calipers etc. Would like to do it as cheap as possible
Re: disc rear axle
Posted: Tue Oct 02, 2012 9:36 pm
by dan_2k_uk
From front- Caliper carriers. Brake hoses. Wheel studs.
From rear- old drums to cut centers out of.
There is a guide in the diy section on the home page.
Re: disc rear axle
Posted: Wed Oct 03, 2012 8:34 am
by dazerede
Hey mate there is a nice set of 410axles on ebay with welded diff and a rear disc conversion I would bid but its 205 miles away from.me
Re: disc rear axle
Posted: Wed Oct 03, 2012 5:29 pm
by Jay30685
What's difference with 410 axle?
Re: disc rear axle
Posted: Wed Oct 03, 2012 7:04 pm
by Edweird
Diff ratio...
Re: disc rear axle
Posted: Thu Oct 04, 2012 9:37 am
Edweird wrote:Diff ratio...
+ narrower+different spring spacing
Re: disc rear axle
Posted: Thu Oct 04, 2012 1:41 pm
by Edweird
ScottieJ wrote:Edweird wrote:Diff ratio...
Thank-you Scott.
Re: disc rear axle
Posted: Thu Oct 04, 2012 3:37 pm
I should say against a samurai axle. 413 axles are the same width and spring spacing as 410 axles but have samurai sized diffs and a slightly lower ratio.
Here's the
axle bible
http://forum.suzukiclubuk.co.uk/vi ... 12/t,2801/
Re: disc rear axle
Posted: Tue Oct 09, 2012 9:56 pm
by 4x4edd
I'm also doing this on my new axle as my old one collapsed where someone had done some shocking welding
But got a quick question. What's the best way of getting the drum brake casing off the shaft? I don't want to damage the bearings as they look new, but don't want to cut the casing.
Any suggestions?
Re: disc rear axle
Posted: Tue Oct 09, 2012 10:11 pm
by Darrell
How did you get to see the bearings when the drum is still on the shaft. You need to undo the 4 bolts behind the drum to remove the shaft
Normally the drum is removed with a slide hammer, but the shaft is still in the axle.
