Page 1 of 2
does anyone have a wiring diagram for the ignition coil?
Posted: Fri Sep 14, 2012 11:07 am
by Jay18
i am fitting an electronic ignition and need to know what wires do what, so if anyone can tell me by the colour of the wires or a wiring diagram it would be a great help!
thanks in advance...
Re: does anyone have a wiring diagram for the ignition coil?
Posted: Fri Sep 14, 2012 11:30 am
by Darrell
This do ya -
Posted: Fri Sep 14, 2012 11:39 am
by Darrell
I assume you have the correct coil for electronic ignition as well
Posted: Fri Sep 14, 2012 7:56 pm
by Jay18
i knew i could count on you having a diagram! lol and i need a new coil? i have bought a blacktop universal electronic ignition that wires into the original wiring which is why i needed the diagram...
and i have a sj410 is the coil wiring the same as the 413?
Posted: Fri Sep 14, 2012 8:05 pm
by Darrell
The 410 coil has a ballast resistor fixed to the side. This limits the voltage to the coil to about 9v I believe. This ballast resistor is by-passed under starting only. If it was fed 12v all the time I would expect it to overheat.
Any more info about the kit you have brought.
Diagram as shown in workshop manual (I haven't seen one with my own eyes
I would assume that it would have either black/yellow to solenoid or black/green to starter. Not both as they both do the same job of supplying 12v on start-up.
Posted: Fri Sep 14, 2012 8:16 pm
by Darrell
I would expect your kit to just replace the points so I doubt if you need to change the coil, I only suggested this as I assumed you had a 413 dizzy to fit
Posted: Fri Sep 14, 2012 8:17 pm
by Jay18
its in the gloveox at the moment with the instructions lol but this is the one..
Click Here for Ebay Listing
Posted: Fri Sep 14, 2012 8:42 pm
by Darrell
I think your need to fish out the diagram that came with it. A little strange as it still uses the points, but I assume it takes the current off them which will make them last much longer and therefore keep your timing correct for longer.
I always thought electronic ignition was to do away with the points
Posted: Fri Sep 14, 2012 9:18 pm
by Darrell
Had a look on fleabay and it says the 4 wires are power,earth,coil & contact breaker, so it's like this ??
Posted: Fri Sep 14, 2012 11:12 pm
by Jay18
thanks mate! thats saved me alot of thinking lol will get that done soon also have to change the points as ive got a new set so need to get myself a timing light..
get that done, bit of underseal here and there, paint front bumper and off the ATS for the MOT starting to get a bit excited now lol...
