Advice on brakes
Posted: Wed Sep 12, 2012 12:46 pm
by dunnin21
I'm breaking a vit at the min, iv took the front calipers off do these bolt straight on to my sammy or will I need discs off vit and any other parts. Thanks andy
Re: Advice on brakes
Posted: Wed Sep 12, 2012 9:50 pm
by Darrell
Sure you will need the discs as these are vented and therefore wider. Not sure about anything else, but have read that they are a straight swap. Hopefully someone who has done this will give better advice
Posted: Wed Sep 12, 2012 9:56 pm
by Darrell
Posted: Thu Sep 13, 2012 9:36 am
Depends on what model vit, swb vits use the same discs, you need the caliper hangers as well, also you need to bleed the calipers with them unbolted and rotated so that the bleed nipples are at the top. I run swb vit calipers on the front of mine.
Lwb vits have vented discs so you need the discs as well.
